FAQ's(Frequently Asked Questions) F2
Old May 4, 2010 | 07:53 PM
Krux's Avatar
Default FAQ's(Frequently Asked Questions) F2
Hey guys figure I would make a list so this would help everyone out with questions that come along. If you have anything good or want to add let me know and ill add it to the list. I left blanks since I myself have no clue.
Here are the most common questions asked about the F2:
Are these bikes fuel injected:
No. 4 carbs
Grade Gas:
87
What are the most common power mod's to do:
1.-1 Front Sprocket, +2 Rear Sprocket
2.Slip On(aftermarket exhaust)
3.Air Filter
4.Rejet
What are the most common body mod's to do:
1.Undertail kit
2.Hid's
3.Good frame sliders(One's that require no cuts haven't had significant luck with working)
4.Tires(Find a good brand name that's proven to work)
5.Aftermarket Windscreens
7.Good Chains
What are some good websites to get parts for it:
Oem:
www.bikebandit.com
www.servicehonda.com
Aftermarket:
I hear a rattle when start up and at 5,000 rpm's. What is it?:
CCTL Link:
https://cbrforum.com/forum/cbr-600f-15/how-cct-40124/
My valves tick is this normal?:
Yes this is. In order for your valves to work properly you need to have clearance. With having clearance you get a "ticking noise" which is normal. If you don't have any clearance they will be to tight you will have major major problems.
Are the F2 good??: Here is the super review on it with spec's:
https://cbrforum.com/forum/showthread.php?t=96801
Old May 4, 2010 | 08:21 PM
Sand.Man's Avatar
The F2 has 4 carbs
Old May 4, 2010 | 09:52 PM
berga's Avatar
While BikeBandit is a good resource, servicehonda.com has better pricing on nearly all parts and also (in my experience) ships faster. In my experience servicehonda parts arrive 3 days faster and cost less.
Old May 5, 2010 | 12:01 AM
chutneybutters's Avatar
um... i think that articly you posted is about the f4i.
Old May 5, 2010 | 07:20 PM
RoosterF3's Avatar
ummmmm okay, I'm thinkin of an f word right now
Old May 6, 2010 | 06:14 PM
Krux's Avatar
I did this for the F4i but I just copied and pasted it for each section and did it fast. This way the mods in each section can work with this.
Old May 10, 2010 | 07:43 AM
ChickenBaconRanch's Avatar
What positions of the petcock do what?
Pointing down, forward, and up
Old May 10, 2010 | 09:58 AM
Sand.Man's Avatar
UP - Reserve
Forward - Off
Down - On
Krux
May 31, 2021 02:48 AM
Krux
May 8, 2010 03:09 AM
Krux
May 7, 2010 08:42 PM
Krux
May 6, 2010 08:10 PM
Krux
May 4, 2010 08:41 PM
