FAQ'S(Frequently Asked Questions)929
Old May 4, 2010 | 08:24 PM
Krux's Avatar
Default FAQ'S(Frequently Asked Questions)929
Hey guys figure I would make a list so this would help everyone out with questions that come along. If you have anything good or want to add let me know and ill add it to the list. I left blanks since I myself have no clue.
Here are the most common questions asked about the 929:
Are these bikes fuel injected:
Yes
Grade Gas:
What are the most common power mod's to do:
1.Power Commander
2.-1 Front Sprocket, +2 Rear Sprocket
3.Slip On(aftermarket exhaust)
4.Air Filter
What are the most common body mod's to do:
1.Undertail kit
2.Hid's
3.Good frame sliders(One's that require no cuts haven't had significant luck with working)
4.Tires(Find a good brand name that's proven to work)
5.Aftermarket Windscreens
6.Flush mounts(Blinker lights)
7.Good Chains
What are some good websites to get parts for it:
Oem:
www.bikebandit.com
Aftermarket:
My valves tick is this normal?:
Yes this is. In order for your valves to work properly you need to have clearance. With having clearance you get a "ticking noise" which is normal. If you don't have any clearance they will be to tight you will have major major problems.
Size of front and back tires stock:
Old May 7, 2010 | 05:38 PM
johnnycrash's Avatar
Grade Of Gas: 91 octane or higher 94 if you can find it!!
Stock tire sizes are: Front 120-70-17, Rear 190-50-17
Any other questions?
Old May 8, 2010 | 03:09 AM
bubba_finch07's Avatar
actually the octane rating is 91 ron which is 87 US octane. I still put premium in mine, just saying.
Krux
May 31, 2021 02:48 AM
Krux
May 10, 2010 09:58 AM
Krux
May 7, 2010 08:42 PM
Krux
May 6, 2010 08:10 PM
Krux
May 4, 2010 08:41 PM
