Engine not stable and speedo got made, CBR600F4
Hi.
My CBR600F4 start acting strange.
The engine start sputtering and throw backfires.
The speedometer stopped working.
I'm not sure what is the cause for this problems. I've read it might be related to a faulty speedo sensor, but I'm not sure.
I've tried to find speed sensor for my bike, from what I understand the part number is 37700MBW611, But the part seems to be out of stock. I found the sensor for the 2001 model, 7700MBWJ21, It's looks the same but i'm not sure if its compatible.
Do you have an idea what is causing the problems in my bike? it worked perfectly, I didn't ride it for two weeks and then its started.
Do you know if the speedometer sensor for the 2001 model will fit my bike (1999 model)?
Thank you.
Ofir.
Thank you.
Ofir.
Hi.
Thank you.
Ofir.
Thank you.
Ofir.
I have the same problem with my F4
