Speedo/Odo problems-speed sensor
Old Oct 8, 2012 | 08:21 PM
Rossaj's Avatar
Registered Users
Default Speedo/Odo problems-speed sensor
I have just bought a 2001 CBR F4I and the speedo and odo are not reading. Speedo always zero which causes odo not to change. I have done some research and saw it might be VSS. I am new to motorcycles so if someone could help me that has had same problem go through the wires I should check before buying new VSS and if not a location where I can get a VSS (if other years/models VSS will fit this bike. Thanks so much!!
Old Oct 8, 2012 | 10:07 PM
YeOldeF4i's Avatar
https://cbrforum.com/forum/how-mecha...r-swap-110034/
I have the same problem. Speedo and, therefore, the odometer have been working for me intermittently. This is on my lengthy to-do list (that may be pushed back if winter comes this year)
Old Oct 8, 2012 | 10:15 PM
curley444's Avatar
Default speed sensor
If your speed sensor is bad it will throw a code. The service connector is under the seat right by the ecu.
Attached Thumbnails Speedo/Odo problems-speed sensor-ficodeschart.jpg
Old Oct 8, 2012 | 11:22 PM
C Jacob W's Avatar
sounds like a speed sensor,Mine was doing it when i first got it. Just replace the speed sensor, its not a fun job. and it should be flashing a code
Old Oct 8, 2012 | 11:38 PM
Rossaj's Avatar
Registered Users
So if not flashing code then a wire is probably just disconnected or loose? Does anyone know the common wires that disconnect that could cause this?
Old Oct 12, 2012 | 07:45 PM
Rossaj's Avatar
Registered Users
So just go to bike and was checking the things I have heard to check like to see if any code and when checking a green and pink plug was out of ecu. It has been said this is speed sensor but I cannot find a spot to plug into ecu. Wondering if anyone can help of where this goes. Thanks
Old Oct 12, 2012 | 08:02 PM
Rossaj's Avatar
Registered Users
I just got to bike and pop open seat and there is a green and pinkish plug out of ecu and understand that is speed sensor? But i cant see a spot where the plug could possible go. Please help!!
snakedavid
Jul 18, 2013 03:18 AM
Beez Motorsports
Oct 15, 2012 06:33 PM
dellenty2002cbr
Jun 10, 2011 06:19 PM
SpaceDocking
Jan 2, 2007 08:09 PM
