speed sensor
Old Jul 11, 2013 | 06:47 PM
snakedavid's Avatar
New Member
Default speed sensor
Please help:Where is place for speed sensor on my cbrf3 1996,i need a picture
Old Jul 18, 2013 | 03:18 AM
gpfan1's Avatar
The speed sensor is accessed from the right side after removing the tank and the fairing lower. The connector is next to the coolant elbow that goes into the cylinders. Follow the cable from the connector to the sensor that is located behind the cylinders on the crankcase. If you remove the two bolts it will come off. You need to plug the hole with a clean rag until you replace the sensor. You also need to replace the rubber o-ring. Don't have a picture.
Beez Motorsports
Oct 15, 2012 06:33 PM
LoneWolf04
Jul 2, 2010 05:37 PM
dscort
Feb 1, 2008 03:33 PM
kukku
Nov 13, 2007 02:48 AM
