Dead Cluster & Blowing Fuses
Old May 22, 2012 | 01:46 PM
MaxmotoMarcos's Avatar
New Member
Default Dead Cluster & Blowing Fuses
Hey Guys, i did some searching and it seems some people have had a similar problem, which was easily fixed by just replacing a blown 10a fuse.
I'll go into a little detail as to what happend. I went for a 30-45 minute ride, near the end of it i noticed my neutral light wasnt turning on. i just assumed it may have blown, didnt pay too much attention to it. I then noticed my blinkers werent working and neither were any of my gauges. i made it to my friends house. I checked the fuses and of course the 10a fuse which is for the tail light, blinkers, horn and cluster was blown. My friend had a spare so i popped it in and turned the key and perfect, all the lights worked. i tapped the horn and just as it honked, it blew again.
i changed it again and also noticed the 30a main fuse went too. so i changed that, but each time i put a new 10a fuse in, it blows again.
I'm about to head over to my friends house and have a look but just thought i'd ask on here as searching these forums have helped me a great deal.
My guess would be that maybe in time, one of the wires was touching something hot and slowly the insulation was being melted away until the metal from the wire touched whatever metal it was rubbing against?
bike has about 20k km hasnt seen any rain.
any thought would be greatly appreciated. like i said, i've done some searching and everyone seemed to fix it by just changing the blown fuse. i do that and it keeps happening.
thanks in advance.
Max.o
Old May 22, 2012 | 05:28 PM
cbtrez's Avatar
Hmm obviously it is a short to ground, but the question is where ? I think your going to have to use a multi meter while taking your bike apart to isolate the forward wiring harness from the main one.
Old May 22, 2012 | 05:44 PM
New Member
Hey, Thanks for the reply, i seem to have fixed it. Seems like it may have been a bad connection @ one of the relays. When i got to the bike i put in another fuse and sure enough it blew. I read on here some people having a similar issue and having to replace a relay so i took out the back fairing and unplugged and re-plugged them all and made sure the wires werent loose. put a 10a fuse again and it seemed to have worked. one of the relays was hanging instead of being seated in the holder...not sure if that had anything to do with it....its raining now so hopefully in a few hrs i can ride it back home. i have about 30 spare fuses there right now just in case lol.
thanks for the reply and hopefully i don't find myself back on this thread seeking for answers.
Old May 23, 2012 | 08:38 AM
exodus191's Avatar
I had this same exact problem. Will take a look at the relays. Thanks
Old May 24, 2012 | 05:31 AM
New Member
Just thought I'd also mention when I was out on my ride before that happend, I kinda got stuck in sum pretty bumpy old broken up road. Lots of bumps and I noticed the problem happend soon after I passed that area.
Old May 24, 2012 | 06:45 PM
Pugheaven's Avatar
I'm getting the same thing under hard acceleration now... today had 3 fuses go taking out the dash and indicators and trip computer... BUT just put a new Motobatt YTX9-BS... now, this is meant to be fine with my bike and a cracking quality battery replacing the cheap **** I had in it beforehand, BUT just wondering, this battery delivers 10.5Ah instead of the 8.0Ah my Haynes Manual says for the battery...
Could this be causing a problem? None of the other fuses have gone... just this one... and with it go the indicators, all dashboard lights/dials... and trip computer. Put new one in 3 times today... 1 went within 2 minutes, 1 lasted for a few hours, however, I've noticed it when I tank it, and I mean tank it from 2nd gear... noticed it seems to go then, might be coincidence?
Either way, any ideas, could a battery do this to one particular fuse? And does this 10.5A delivery fo the new battery make a difference? Can't think of anything else, checked all the wiring it's fine... and like I say, 3 fuses, all lasting different times BUT I would say they've gone when tanking it.
hmm
May 8, 2012 07:57 AM
ZBike
Mar 24, 2012 04:38 PM
Cobretticuz
Jul 30, 2011 02:16 AM
bluefire7321
Feb 19, 2007 12:30 PM
soapdish
Oct 14, 2006 12:33 AM
