Changed my cct & still have the tick
Old Aug 28, 2012 | 06:30 PM
young7.3's Avatar
Default Changed my cct & still have the tick
Well I changed the cct and put a manual APE in and it still ticks just the same amount. Anyone have any ideas? Does the chain itself need replaced?
Old Aug 28, 2012 | 08:31 PM
74demon's Avatar
Are you sure Its the chain that's making the noise?
Old Aug 28, 2012 | 09:17 PM
chainstretcher's Avatar
Admin Emeritus & MVN
It is really hard to tell without hearing it. More often than not motorcycle engines have a tick. It's perfectly normal. If it is loud or rattles on decel than it's possible you have tensioner problems. Can also be a sign that valves need to be adjusted. Shim under bucket is a fairly robust set up but nothing lasts forever and wear in the valve train can cause a tick.
Old Aug 29, 2012 | 09:43 AM
young7.3's Avatar
I'm almost positive it it's the chain. I had a 94 f2 that had the ticking and a manual remainder fixed it. I'll try to load a video later.
supersnake83
Jul 5, 2009 01:56 AM
rickscbr
Sep 13, 2008 10:17 AM
wande00
Jun 23, 2007 05:08 PM
byc_panty
May 12, 2007 10:20 AM
Eminent
Dec 13, 2006 10:56 PM
