chain issues please help
Old Aug 15, 2011 | 05:44 PM
ohio nitro's Avatar
Default chain issues please help
i just replaced my chain and front,rear sprokets due to being worn out and rear sproket being warped. and it was causing my chain to jump and make some really scary popping sound but not jumping teeth or coming off. now that I have a new chain and sproket and all new bairings I am running into the same problem again if I have it on my stand and put it in gear the chain is jumping around. so I guess my Q is should I be cocerned.
Old Aug 15, 2011 | 05:50 PM
gotcbr's Avatar
Please tell me that you're not running your bike while its on the stand.
Check that you're using same size chain & sprockets.
Verify wheel alignment. Make sure your axle is same on both sides in swingarm.
Old Aug 15, 2011 | 06:04 PM
MadHattr059's Avatar
+1 gotcbr
Look down the chain at the top, is it a straight line? Or does it 'dog-leg"?
How much slack at the center of the chain's lower run? Should be no more
than 1" total travel, max.
It is NOT normal behavior and you shouldn't ride the bike until you get this
figured out. If the chain 'jumps', it can lock-up the rear wheel without any
warning. THIS IS A BAD THING.
Hope you get this figured out, let us know.
Ern
Old Aug 17, 2011 | 09:50 AM
UnderAssumedName's Avatar
I had that too when I bought my F4 (with worn chain). My allignment was off.
MaikuMizu
F2 Tech
Jun 20, 2016 09:50 AM
Krux
Nov 16, 2011 08:06 PM
Krux
Jul 3, 2011 10:00 PM
doc_diggumz
Sep 29, 2009 03:54 PM
weymouthb
Sep 30, 2007 11:51 PM
