bogging and dieing
Old Aug 11, 2011 | 01:44 AM
derpingeverywhere's Avatar
Default bogging and dieing
Just bought a 2000 600f4. 9000 miles. After driving it for about 10 minutes it started to bog down and then die. Took a minute or two before it would start back up and then started back up in high RPM. This happened about 4 times before i got back to my house (20 minute drive). Any have any idea what the problem might be?
Any help would be greatly appreciated.
Old Aug 11, 2011 | 08:08 PM
Carbs are in great shape. Could it be the fuel relay?
Old Aug 11, 2011 | 09:07 PM
Turbulenz's Avatar
Official Welcome Crew
It could be anything.... I'd lean towards the fuel pump though
Do you have any other info from diagnosing the problem?
Good luck
Old Aug 12, 2011 | 12:56 AM
Nope. Happened again today. If i try and turn it on right after it cuts out sometimes it will start up, but the second i try and give it any gas it just cuts out again. I wish i could be more specific but this is my first bike.
Old Aug 17, 2011 | 09:53 AM
UnderAssumedName's Avatar
Yes, maybe the fuelpump. Mine is toast (it pumps but it leaks) Disconnect it and see if it will run whilst gravity fed. Or you could just check if the pump is pumping to start off with.
barryem
Apr 20, 2007 03:05 AM
barryem
Apr 19, 2007 11:32 PM
SchiraF4I
Mar 16, 2007 01:56 AM
Tiller7
May 6, 2006 01:26 PM
BRC223
Apr 24, 2006 04:58 PM
