DIEING BIKE
lately when i just start up my bike it keeps dieing i have to lean it over to the left or the right i hit the starter and it cranks and ies cranks and dies then will sputter for a little and die i do this for a while lean it start it lean it start it, then when i get it started it will run pretty good when it runs for a while it keeps running
help me
help me
By having to lean the bike over to get it to run would make me think either your tank is running low on gas, and you should either fill it up some, or switch it to reserve.... or
Your fuel cut-off relay might be messed up. Try checkin to see if you have voltage to your fuel pump when it dies next time.
