DIEING BIKE
Old Apr 19, 2007 | 10:31 PM
barryem's Avatar
Default DIEING BIKE
lately when i just start up my bike it keeps dieing i have to lean it over to the left or the right i hit the starter and it cranks and ies cranks and dies then will sputter for a little and die i do this for a while lean it start it lean it start it, then when i get it started it will run pretty good when it runs for a while it keeps running
help me
Old Apr 20, 2007 | 12:05 AM
transamlt1man's Avatar
Default RE: DIEING BIKE
It sounds like it is having trouble getting fuel. Maybe getting to the carbs. Are u using the choke?
Old Apr 20, 2007 | 03:05 AM
Fatboy's Avatar
By having to lean the bike over to get it to run would make me think either your tank is running low on gas, and you should either fill it up some, or switch it to reserve.... or
Your fuel cut-off relay might be messed up. Try checkin to see if you have voltage to your fuel pump when it dies next time.
kingofidk
Jun 20, 2012 06:39 PM
barryem
Apr 19, 2007 11:32 PM
uponone33
Jun 1, 2006 03:04 AM
Tiller7
May 6, 2006 01:26 PM
BRC223
Apr 24, 2006 04:58 PM
