CCT still making noise
Old Jun 3, 2014 | 03:21 AM
markybwoi's Avatar
Originally Posted by Boyo
I suggest using a Manuel cct, check the guides for abnormal wear and tear.
Whats it like checking the guides is it doable with the engine in?
Mine is much quieter now i done the oil change and i also wound the tensioner screw inwards as hard as i could, it now makes less noise when at normal temp and disapears
When the engine is very hot (when fan comes on) i am going to try a manual cct and see what the outcome is.
It can only be the guides or tensioner at fault really.
Old Jun 3, 2014 | 06:40 AM
Conrice's Avatar
If you've made that tensioner as tight as you can - you will have some problems eventually with the cam guides.
Did that faint tapping go away that you heard at 7/8 seconds into your video?
(a little bit of rattle is to be expected by the way)
Old Jun 4, 2014 | 06:22 AM
markybwoi's Avatar
Its back again its a lot fainter then it was before the oil change but still there. Yer i have the normal rattles etc this sounds like a knackerd tensioner
Old Jun 9, 2014 | 12:22 PM
markybwoi's Avatar
Does any one know is a manual tensioner from a 98 cbr will fit a 99 f4?? Or know where i can get a manual one for mine
Old Apr 23, 2020 | 09:41 PM
Jacob Fiddler's Avatar
Originally Posted by CR41G
Could it not be that the cam chain has stretched beyond the opperation of the tensioner causing it to continue to rattle??
Did you ever figure the rattle out? I'm having same problem. thinking about installing a new Cam chain. curious if anyone figured out the problem before i ordered chain
Old Oct 29, 2022 | 02:32 PM
johnhorgan's Avatar
And did you ever figure out the problem ?
I will post when I figure out the problem.
jfalcon
Oct 20, 2011 03:24 AM
foxxg1h
Apr 30, 2010 11:37 PM
voland
Jul 30, 2009 08:42 PM
quaddict53
Dec 30, 2008 12:08 PM
etherimos
Feb 20, 2008 11:14 AM
