Carb problem...
Old Mar 31, 2010 | 09:32 PM
Inflame's Avatar
Default Carb problem...
Ok well I recently got my bike running again, well... kinda...
When I try to start it, it starts then dies because the engine gets flooded with fuel... If I go full throttle it won't hold the revs Also, when I shut the bike off, I can hear the carbs fill up with fuel. There is gas coming out the JET NEEDLE/MIXTURE NEEDLE!! AFTER the bike is OFF
I cleaned the float side and the vacuum side of the carbs. What could be causing this?
Thanks,
Bart
Old Mar 31, 2010 | 10:14 PM
jonld's Avatar
Needle valves are crap or floats are damaged. You can hear the carbs fill with fuel? Like the pump is still running or you hear fluid trickling?
davrosxuk
Aug 26, 2008 04:24 PM
Heffer2586
Apr 16, 2008 09:39 PM
jasonp
Jun 8, 2007 12:26 AM
Trips
Nov 26, 2006 01:45 AM
jrizzno40
Jul 25, 2006 04:59 PM
