carb problem?
Old Jul 25, 2006 | 01:59 PM
jrizzno40's Avatar
Default carb problem?
i just got a 92 f2 and its fires up but when you go to give it throttle it cuts off... the guy i got it from said that he just cleaned the carbs........and before he did he was messing with them and probably got them out of sync if anyone can tell me what might be happening i would be grateful........ my buddy seems to think they are getting to much fuel.......please help
Old Jul 25, 2006 | 04:43 PM
MT Wallet's Avatar
Default RE: carb problem?
maybe the jets are plugged?
I dunno...but at low speed my bike lurches a bit and is rough...at higher speeds I guess the other jet kicks in and it's fine.
Old Jul 25, 2006 | 04:59 PM
woot's Avatar
Check your sparkplugs. If they are dark you're buddy is right.
If someone messed with the carbs and didn't know what they were doing then start there.
Likely the bike wasn't running well. They did a half *** cleaning job ( got all the big areas but didn't properly get the small MUCH MUCH more important parts )
Carb cleaner is a half assed cleaner... it's ok but if the carbs are a mess it's better to take them apart.
Carb sync and colour tune would get you a long way there... if anyone is doing a carb clinic get on board. Otherwise start at the factory settings and work from there. If you don't have a carb sync tool you can build a 2 carb tool from bottles and tubing... just sync one bank, then the other and then sync the banks.
I've rambled.
Start from the beginning. Ensure you have a FULLY charged good battery. Poor spark won't help. Then check your plugs. They'll give you an idea of how the engine was running when it was turned off. As this is a low rpm problem they should be telling you the symptoms right now as is. Get a spare set of plugs to use for testing.
Inflame
Mar 31, 2010 10:14 PM
davrosxuk
Aug 26, 2008 04:24 PM
Heffer2586
Apr 16, 2008 09:39 PM
jasonp
Jun 8, 2007 12:26 AM
Trips
Nov 26, 2006 01:45 AM
