Carb Problem
Old Apr 16, 2008 | 09:23 AM
Heffer2586's Avatar
Default Carb Problem
My buddy has a bike and the bike runs fine for a little while then starts to bog down while giving it the throttle. And when he drains the oil a lot more comes out then he put into it. Could the gas be getting into the oil some how??? I'm thinking Diafram or something likethat maybe.Haven't seen it asked yet so decide to post.
Old Apr 16, 2008 | 12:40 PM
lonewolfcbr's Avatar
Default RE: Carb Problem
Did this bike sit for a while? Like over winter storage? I have the same problem...bogs down...can't get up in speed without WOT...and its hurting gas mileage bad. I know i have a rich problem...need to check my plugs sometime soon. As for the oil...is he draining it while hot? As with just about any luquid..it'll expand a bit when heated...and if it's a whole bunch of oil compared to what was put in there...does it smell of something else other than oil? I'm sure you would smell the gas
Old Apr 16, 2008 | 01:09 PM
woo545's Avatar
Huh?
Actually, I don't know what you mean by getting a lot more oil out then he puts in...the bike holds something like 4 qrts of oil or something like that...I would have to check the manual, if it's an F2.
As for bogging down, could be clogged jets. If it's been sitting, try tossing some seafoam gas treatment in the tank. Beyond that, I would have the carbs removed and thoroughly cleaned.
EDIT: If Oil was getting a into the cylinder, than you would see smoke and you would end up with less oil, eventually.
Old Apr 16, 2008 | 02:08 PM
Heffer2586's Avatar
What i am saying is that he drained the oil after this happened and a **** load of oil came out way more then 4 qts. dont know if the gas could leak by somewhere in the carbs and drain into the oil or not.
Old Apr 16, 2008 | 04:08 PM
cowboy from hell's Avatar
ORIGINAL: Heffer2586
duno bout that either but posibilty is someone fuged a jet kit install. i mean if it runs good cold then runs like **** after warming up that sounds like richness which=unburned fuel. what do the sparkplugs look like?
Old Apr 16, 2008 | 04:38 PM
GARMIN1000F's Avatar
pull the carbs a clean them with carb cleaner. read the manual has everything you will need to know. also take a look at the petcock on the tank. I think mine has gone out and is causing the same exact issue.
Old Apr 16, 2008 | 09:39 PM
Heffer2586's Avatar
alright thanks for all your help everyone
Inflame
Mar 31, 2010 10:14 PM
davrosxuk
Aug 26, 2008 04:24 PM
jasonp
Jun 8, 2007 12:26 AM
Trips
Nov 26, 2006 01:45 AM
jrizzno40
Jul 25, 2006 04:59 PM
