Bike wont stay on
Old Aug 21, 2006 | 04:23 PM
blairsbike8's Avatar
Default Bike wont stay on
Bike starts but as soon as i let off the throttle it shuts off. It was running great up until this happened. Went to pick something up down the road, it didnt start as easy as normal but it did start and I went down the street w/o a problem. As i was leaving it was harder to start and turned off as soon as i let off the throttle. Has this ever happened to anyone, any suggestions??
Old Aug 21, 2006 | 06:10 PM
ValleyCat's Avatar
Default RE: Bike wont stay on
How long does the engine run before it stalls? Was the choke used? If so, how? Does this happen daily? Does it happen with engine hot or cold? Will the engine start and run normally the rest of the day (so to speak)? Does the problem only reappear next day after engine has cooled to room temperature?
Any additional details is helpful.
Old Aug 21, 2006 | 07:15 PM
This just happened for the first time the other day. Before this the bike started up with no problem and ran fine. The other day for the first time the bike took some more throttle to start and when it did start it would die as soon as i let off the throttle. I was at the store when this happened and it stopped everytime i let off. It would start right back up if I held the throttle but then die at the next stop/light.
Old Aug 21, 2006 | 07:30 PM
MikeMirage's Avatar
I had a smiliar problem when the shop forgot to plug a vaccum hose in. I am thinking maybe you need new hoses. Other than that check your spark plugs. That is all I can think of right now!
Old Aug 21, 2006 | 07:51 PM
ValleyCat's Avatar
There are many issues it could be but start simple. Check your hoses, it could be vacumn related but it Sounds like maybe the carbs are gummed/plugged up and need to be cleaned. When was the last time they were looked at?
Old Aug 21, 2006 | 07:57 PM
Thanks for the responses. I've put about 2000 miles on it since buying and that is the last time anyone has looked at it. I'll check the hoses and carbs tonight and hope that it is something simple i can tweak back into place.
Old Aug 21, 2006 | 08:09 PM
ValleyCat's Avatar
Let us know what you find out after checking it out and perhaps we can keep trouble shooting for you.
Good luck!
Old Dec 31, 2007 | 01:30 PM
js2's Avatar
js2
I am encountering the same issue right now. Did the vaccum hose end up being the problem ? If not what did you end up finding to be the problem.
Jay...
Old Jan 2, 2008 | 08:04 AM
Bumble Bee's Avatar
My F4 will start up when it's 18 degrees out with no gas, just full choke. Have you always had to start it with the gas twisted? When it does not stall out, what RPM does your bike idle at? Stock setting shoud be about 1200 to 1500 RPM's
dad0507
May 2, 2014 09:50 PM
Servtex
Jul 22, 2013 01:44 PM
VR4-F4I
May 1, 2012 03:16 AM
blakesgst
Oct 8, 2009 10:46 AM
alekinci
Jun 13, 2007 12:52 AM
