bike dies/starving of fuel
Old Oct 26, 2018 | 01:07 PM
Here2Ride's Avatar
Default bike dies/starving of fuel / parasitic drain in cluster
Ive had several issues with this bike since ive gotten it, thought it was all fixed and now this... the distance/time varies between 5 minutes and 10 minutes, I think it depends on how much I get on the throttle. Like I said in the title, it feels like its starved of fuel and will slowly die over a period of 5-10 seconds. After it dies I have to let it sit for roughly 60 seconds then start it back up with full choke then rinse repeat. Ive read on another post about the fuel pressure cut off contacts being bad and that will be my first stop or is this a sign of a failing fuel pump? what steps should I take here? Thanks
EDIT*** Scroll to post #25 for parasitic drain start.
Old Oct 26, 2018 | 02:42 PM
The next time it happens try opening your fuel cap and see if that helps. Or you could just try running with the cap opn and see if it happens. If this fixes it, you have a pinched or cligged breather tube
Old Oct 26, 2018 | 07:20 PM
Here2Ride's Avatar
Thanks for the reply, thats the first thing I tried when it first started happening.
Old Oct 26, 2018 | 07:45 PM
Good deal. then I would remove the fuel line at the input to tue fuel pump and check the flow. that should tell you a lot.
Old Feb 20, 2019 | 03:59 AM
Gjorret's Avatar
Had allmost the same issue. Changed my fuelfilter and havnt had it since. Thought it was pump or maybe battery because it was bad.
Fuelfilter was old, used and dirty.
Old Mar 28, 2019 | 10:29 PM
Here2Ride's Avatar
Sorry it took me so long to bring this up again.. but I didnt get a chance to get around to working on my bike last fall then winter hit. Now that things are starting to warm up a bit in Ohio I started messing with my bike again and replaced the fuel line to the pump including the inline filter and I am still having the same issue. Ive already checked power to the pump. it kicks on and runs fine when you start the bike and has a steady stream. there is no clog in the gas tank vent and no kinks in the intake line to the pump. so all that leaves is from what im guessing is the pump its self is intermittent possibly? (is that a possibility?) I read somewhere once about a contact switch on the pump itself that is supposed to kill the pump at a certain pressure that could be bad? or something in the carbs themselves are clogged but to me doesnt make sense but I can start the bike fine after sitting and open her up down a strip without holding back. So I dont know. is there something im missing in the fuel chain here? to recap from my OP last year if I just putts around low rpm i can drive all day but if i drive WOT give her hell then about a mile down the road she'll ask me "where is my fuel" and die.
Old Mar 29, 2019 | 02:24 AM
CaBaRet's Avatar
Have a look at your DAI hoses, filters and Solenoid, could be starving the engine of air, seems to be coming up quite a lot lately
Old Mar 30, 2019 | 09:01 PM
Here2Ride's Avatar
So you think im having an air flow issue and not fuel? I actually do remember re-attaching a hose to the air box that was just hanging around after installing a new battery last year. I wonder if I can remember which one it was. Ill have to take another peak.
Old Apr 10, 2019 | 12:23 PM
Here2Ride's Avatar
Circled in red is what was the disconnected emissions line when I bought the bike, whether or not it was intentional or not I dont know, but I noticed it when I was installing the new stator so I reconnected it. Did my new problem start around that time because of it or just a coincidence? Not sure but I re-disconnected it and will find out next time I take the bike out. Im not sure what else to look at when you mention to "look at DAI (which im guessing is direct air intake?) and solenoid" Thanks
Old Apr 10, 2019 | 11:41 PM
CaBaRet's Avatar
Yes that hose should be connected, if a Cali bike, but you should be looking at the normal Air side and solenoid,changes the Air flow from 20mph ,tests for checking the solenoid and relays are in the manual page 5-36
