Won't start.... HELP!
Old May 14, 2007 | 11:26 PM
tho418len's Avatar
Default Won't start.... HELP!
Ok, I bought the bike a few months ago, it ran for lil while then it wouldn't start. I changed the plugs, oil, fuel filter,and put some carb cleaner in the carbs. It ran like a champ. I went out the other day to start it, it ran for a minute then it died. Ever since then itwouldnt start. Please Help.
Old May 17, 2007 | 01:23 AM
ynks4evr's Avatar
Default RE: Won't start.... HELP!
i actually had the same thing happen with my bike, i didnt think it was the battery cuase the starter was going and the battery is pretty new, but i put the charger on and sure enough it started up. Not sure if you have tried that but if not give it a shot, it mght work
Old May 17, 2007 | 02:17 PM
tho418len's Avatar
yeah i tried that, still wotn start. it almost wants to start but it doesnt. i think it might be the fuel pump. the fuel pump pumps but i dunno if its at itsfull potential.
Old Jun 10, 2007 | 08:36 AM
ceeber6's Avatar
Hi if you read some of my other replies on the forum it'll sound like i'm a stuck record, regulator/rectifier. Its a small sealed plastic unit that stores energy to run the engine at idle and gives boosts when starting. Have a word with your local bike dealer or search for regulator/rectifier on the threads. Hope it helps, if not its worth a try to cancel something out. You'll be surprised how many seasoned bikers never think of these little things. Good luck
Old Jun 11, 2007 | 11:19 AM
Sproutf3's Avatar
Registered Users
if it will turn over, and occasionally stutter, pull your fuel pump off and hook it up to a battery, see if it's pumping
Old Jun 11, 2007 | 09:51 PM
therabbit's Avatar
ORIGINAL: ceeber6
Not quite. The regulator and rectifier are part of the charging system, they convert the AC output from your stator to a DC voltage (rectifier part) and uses that voltage differential to recharge your battery and run the electrical components on the bike (regulator part). The starting motor pulls current directly from the battery through the starter relay, you could completely disconnect your rectifier and still start the bike fine. What happens when the unit fails is your charging system stops working, your battery is being used to not only start the bike, but keep everything running once it gets going, this is a huge strain on the battery and will quickly burn out cells in it. Once that happens the battery is toast pretty much, motorcycle batteries arenot designed to "deep cycle."
However, it doesn't sound like that is his current problem. I need some more info though, when you say that the bike won't start anymore is it still turning over and there's a problem with no ignition/fuel/combustion? Or is it not even turning over at all anymore?
Old Jun 23, 2007 | 09:52 AM
ceeber6's Avatar
Doesn't the magneto recharge the battery? And the regulator part regulate the amount of current from this?
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
