UPDATE I still need help
Old 04-25-2006, 01:56 PM
SEAN_VANCE's Avatar
Default UPDATE I still need help
Well I charged my battery today (please see post I Broke Down HELP) and went to start the bike, I could barely start it. I never have to use choke to start it and I had to put it to max, as soon as I dropped choke a bit it just died. So I dont think its the Rectifier/Regulator...It seems as an ignition problem. I want to check out the spark plugs etc...DO I have to take off gas tank to remove sparkplugs? Or canIjust take off air cleaner assembly?
Also, whats the most common ignition problems for these bikes, can it be the coils? Is the only way to test coils is with one of those multitesters?
Any info apreciated thanks!
Old 05-08-2006, 04:28 PM
Default RE: UPDATE I still need help
should be able to take off the inspection doors and use a spark plug socket with a small extention to get to the plug. but you shouldn't have to take off the gas tank. i used a socket with a small extention and a small magnet to get the plug out of the hole.
hope this helps!
DRam
08-20-2014 05:25 PM
Noe
04-04-2009 10:17 AM
isolated1523
05-14-2008 02:38 PM
samill42
03-26-2008 02:00 PM
ShadowX
04-15-2007 10:51 PM
Quick Reply: UPDATE I still need help
