UPDATE I still need help
Well I charged my battery today (please see post I Broke Down HELP) and went to start the bike, I could barely start it. I never have to use choke to start it and I had to put it to max, as soon as I dropped choke a bit it just died. So I dont think its the Rectifier/Regulator...It seems as an ignition problem. I want to check out the spark plugs etc...DO I have to take off gas tank to remove sparkplugs? Or canIjust take off air cleaner assembly?
Also, whats the most common ignition problems for these bikes, can it be the coils? Is the only way to test coils is with one of those multitesters? Any info apreciated thanks! |
RE: UPDATE I still need help
should be able to take off the inspection doors and use a spark plug socket with a small extention to get to the plug. but you shouldn't have to take off the gas tank. i used a socket with a small extention and a small magnet to get the plug out of the hole.
hope this helps! |
