tire question
RE: tire question
its not about the biggest tire you can fit on there. and if you do track days then you should understand the impact of changing between a 160/170/180 rear tire and how said changes affect handling, corner speed etc.
there are already quite a fw threads on here about tire size and which brand is better. you will do better by using the search function .. read through it , and if you still cant find your answer then feel free to post a new thread.
RE: tire question
Be carefull with tyre choice, i know triax has a 120/70 front but its turns in rather quick. If your not really confident of holding your front end and your not a quick rider i'd advise against putting a 70 front tyre on and stick with a 60. Cos once it gets to a certain lean angle it may give a little more than your used to. Oh and it rubs on the inside of the fender when hot. Up to you but Honda design fairings around tyres also.
RE: tire question
ORIGINAL: bindelsf2
120 front and 180 rear fool! you are at the widest you can go.. go to redline and get a set of qualifiers since we get a 20% discount there...
Thx.
