Engine hesitation
Old Jun 12, 2007 | 02:48 AM
Paulie's Avatar
Default Engine hesitation
Ok so i recently had the carbs on my bike cleaned and it was rejected with stock jets. Now when I drive the bike I notice that between 5500 and 7000 that I lose power. The bike quits pulling and kinda floats thru the rpm. Then I hit the torque curve and it pulls. Also at the top end ( about the last 2k before redline) I get a similar feeling, but not quite as weak. Could this be a timing issue, or fuel related? I'm not sure what to check first. Any ideas are greatly appreciated.
BTW: Bike is 100% stock.
Old Jun 12, 2007 | 03:02 AM
amaank's Avatar
Default RE: Engine hesitation
If i were you i'd check plugs, air filter etc. Maybe run a bottle of seafoamthrough it.
Quite frankly i don't know what's wrong with your bike, i'm just making suggestions. [sm=smiley20.gif]
Old Jun 12, 2007 | 10:32 AM
Sproutf3's Avatar
Registered Users
if you just had the carbs cleaned, did you have them syncronized? mmmaybe that could be a problem
Old Jun 12, 2007 | 09:38 PM
tyro1shooz's Avatar
its prolly a lean out condition-jet it up and look at hte fuel filter and all vacuum lines(ram air and carb lines)...i think i might have responded to some of the same q's on a different forum....if i did.......sry to be redundant, redundant, redundant, redundant............
JankCibberf2
F2 Tech
Jun 2, 2011 01:15 AM
pitcru05
Oct 15, 2010 11:20 AM
exopforce
Sep 10, 2009 01:51 PM
sHk|HomiCide
Aug 31, 2009 10:43 PM
ImStricken
Jun 20, 2009 11:30 AM
