Hesitation!!
Old Sep 1, 2009 | 06:47 PM
exopforce's Avatar
Default Hesitation!!
My bike is hesitating when I go around 6 rpms.I start speeind up and the bike hesitates I check the fuel lines and they were clean so I have no idea what it would be? I need help !
Old Sep 1, 2009 | 07:53 PM
Speedemon636's Avatar
Sounds like fuel pump. Do you have one? If so, you'll have to check to make sure it works.
Old Sep 1, 2009 | 07:58 PM
TROPhouse's Avatar
Take a deep breath. You have a Honda. There's like 15, maybe even more things that could be wrong that might not even cost anything to fix.
Is it only hesitating around a certain rpm range?
Old Sep 1, 2009 | 08:00 PM
Kuroshio's Avatar
Mine is doing the same. The fuel pump was the very first thing I thought of as well. Gonna give it a check tomorrow.
sHk|HomiCide's Avatar
A few of us posted a thread about this a day or two ago that we are also having these issues. Supposedly a Fuel Pump on this bike shouldn't cause that problem.
https://cbrforum.com/forum/cbr-600f3-17/engine-hesitation-99969/
Old Sep 1, 2009 | 08:07 PM
https://cbrforum.com/forum/showthread.php?t=99969
Well it does.. I rode mine w/o one when I bought it and it struggled on hard accel and higher rpm's. The gravity feed is not enough for fast accel.. I just got a pump the other day and now when I twist the throttle, it's instant response all the way up the rpm's
Old Sep 1, 2009 | 08:09 PM
Kuroshio's Avatar
Nobody in that thread posted they had actually tested the pump though. Both the pump and inline filter could cause this according to the Hayne's manual I have.
Since I know I have an electrical issue, anything powered is suspect since I just cleaned the carbs.
Old Sep 2, 2009 | 03:57 PM
Kuroshio's Avatar
Ok just checked my bike and the fuel pump is NOT running. Bout to go try cleaning the contacts on it and the fuel cut off relay.
Will update
Old Sep 2, 2009 | 05:13 PM
cgmiller83's Avatar
The 2 major weak points of honda's: fuel pumps and rectifiers.
Old Sep 2, 2009 | 06:49 PM
Kuroshio's Avatar
Okay, didn't solve the hesitation. It's a little better tho. A harley guy that lives down the block stopped by. He said the bike is running too rich. That you can smell it in the exhaust. He recommended adjusting the jets to lean it out some.
