Hesitation!!
Old Sep 2, 2009 | 06:54 PM
Speedemon636's Avatar
Yeah that could be a problem too (what Kuroshio said) but fuel pump is the starting place to look at.. If it's not that, then start going into more advanced stuff..
Old Sep 2, 2009 | 07:07 PM
Kuroshio's Avatar
Well to start testing the fuel pump, I cheated. Disconnected the fuel pump from the wire harness and ran 2 wires from the battery to the connectors. Sounded like a heart in a hummingbird. So the fuel pump is working.
Checked for continuity between the fuel pump and the fuel cutoff relay. Didn't have any so I cleaned the contacts on both ends of the harness with vinegar and a soft toothbrush. Now when the bike is running, there's a regular pulse from the fuel pump.
My bike is idling pretty rough which is prolly a sign I need to balance the carbs. Just haven't had the will to tear into her again. But I guess I will this weekend. Will update after I balance the carbs.
Oh btw, I have a K&N filter in my bike. But my understanding is that would usually cause the bike to run lean, not rich
Old Sep 9, 2009 | 11:49 PM
lqdcat's Avatar
I think I'm having difficulty with my fuel pump also. Can anyone tell me for sure that it starts pumping intermittently when the bike is turned on or when you press start?
Old Sep 10, 2009 | 01:51 PM
desperado's Avatar
OK, I just answered similar post. You guys have the same issues. Well...I also do. Rectifier...hmmm. I doubt it. But its always good to check. F3 rectifier is a piece...of crap. They burn out easily. I changed mine to Suzuki ones - just beautiful.
Now to the fuel pumps. Start with small things first. I ve had this problem for like 2 years. Changed the pump twice, then changed relay, then bypassed relay. Now I am running without the pump at all. So, just by pass the pump for now. If the bike fires up and rides good the pump or relay might be bad. If the bike sounds rough check the fuel filter and gas tank for a vapor lock. Then get a set of new spark plugs. Check the old ones first. If they are wet that means the carbs are flooding. Make sure the carbs are clean and synched. Make sure all the cylinders are working. Just put a hand on each manifold. If some of them are cold you have a misfire.
I am changing float needles on mine before I put fuel pump back. You should do it also and it should fix the issue.
Good luck.
BTBTBT
Nov 10, 2010 09:09 PM
pitcru05
Oct 15, 2010 11:20 AM
HV Racing
Mar 8, 2009 11:35 PM
Wants a CBR
May 2, 2008 02:17 AM
rrasco
Aug 2, 2006 05:47 PM
