Tachometer for tuning carbs
Old 02-05-2012, 05:13 AM
MadHattr059's Avatar
You are going to want to use #2 as your base. You sync the #1, #3 and #4 to
match it. With the guages hooked-up and the bike warmed-up and running.
Just try turning the adjuster and watch the guages. You'll quickly see which way
the vacume draw adjusts, in response. Then, just hop back and forth and bring
1-3-4 into alignment with #2.
Hope this gets you headed in the right direction.
Ern
  #62
Old 02-24-2012, 01:04 PM
Grkan13's Avatar
I was out of town for business so i came back and finished my synchronization. It's much better now. I've already done with valve clearance checking. So my bike is almost ready for summer 3 or 4 weeks later I'm going to change my oil and again check the synchronization.
It's alreday around 80 degrees in florida so its time to ride
  #63
Old 02-25-2012, 08:18 AM
JScottB's Avatar
Yeah go ahead and rub it in. It's still in the 30's here and we have yet to take ours out for a thorough test ride yet, we still need to get it insured and put plates on it. My son will be home for spring break in a couple weeks and I'm leaving the enviable job of piecing the fairing together to him.
  #64
Old 04-09-2012, 04:17 AM
f3cbrAnt's Avatar
Originally Posted by IDoDirt
On page 18-9 of the shop manual it mentions a test point for diagnoxing the Tachometer. You can use your Actron meter on that test point for reading the engine RPM. One of these days I'll attach a wire and leave it hanging down so I have access to this point without having to remove the upper cowl. It's funny how hind-site is 20/20.
great thread,SORRY to bring it up again!
i am going to check/re-arrange my shims for clearance (probabaly have to order a few new ones knowing my luck!)
maybe buy a compression tester and take compression readings for future reference???---> good idea or waste of money?
put new oil/filter in (air filter is fine,1 year old)
use my carbtune pro to ballance the carbs,
then try this brilliant idea to help to set the fuel/air mixtures.
only problem is my mulimeter-
318 Digital LCD multimeter
as it does not measure Hertz,which is what i need it to measure,correct??
i would require a different multimeter or a rev counter (
Tachometer) more sensitive to be able to see a 50 RPM drop/gain.
is this correct guys? or is there a way to use my rapid 318 mulimeter,sorry when it comes to electrics im
ride safe,and enjoy,
Ant
  #65
Old 04-10-2012, 03:57 AM
JScottB's Avatar
I'm not savvy with electronics so I really couldn't tell you if the multi meter you have could be used as a tach. My meter has more functions than I know what to do with or how to use those different functions. I remember when I first researched this I did run across an article where someone used a meter that didn't have an actual tach function on the meter but came up with a way of using it anyhow as a tach but I don't remember how and i don't have a link to the article. However the article may be of no use to you anyhow being yours doesn't read Hertz because that may be the key, I really don't know.
As far as purchasing a compression tester I think it's a good investment and a "must have" for anyone who does there own maintenance on their bike even if all you do is preventive maintenance. It's just another basic tool that allows you to get a general idea of the health of your engine.
  #66
Old 04-10-2012, 06:41 PM
i would require a different multimeter or a rev counter ([/SIZE][/FONT]Tachometer) more sensitive to be able to see a 50 RPM drop/gain.
Ant
I looked at the specs of your meter, and no, you can't use it for setting the RPM's. You'd need a meter that either is specifically designed to do RPM's, or it's possible that you could have a meter that's capable of reading HZ and use a formula to convert it to RPM's. Easier to get one that is purpose built for measuring RPM's I think.
Doing the Idle Air Mixture adjustment is not an easy one. You'll find that the idle fluctuates a fair amount normally, making a 50 RPM difference tough to see.
  #67
Old 04-12-2012, 07:47 AM
f3cbrAnt's Avatar
thank you guys,very much appreciated.was the answer i thought,nice to check with the pro's though
fuentes2709
02-27-2012 05:33 PM
dewdog
02-17-2010 12:03 PM
tapkutez
05-01-2009 10:03 AM
Fatboy
09-20-2007 11:53 PM
ThisisMickey
04-04-2007 11:06 AM
Quick Reply: Tachometer for tuning carbs
