Speed sensor ... ??
Old Jan 16, 2018 | 06:54 AM
Gatsoblaster's Avatar
Default Speed sensor ... ??
Hi. Any help with this would be greatful thanks .. so I believe the engine from my bike is a 95_98 cbrf,the bike is actually a 91... The engine has three cables that come off the engine (pink,black,green ) believe this to be the speed sensor???? Help so is this an electronic pickup.. think they should go back to the speedometer cut way too short now though,. I have installed an aftermarket guage that came with a magnet for the front wheel as a speed pick up would eliminating this & connecting to the speed sensor work for the speed..
I also have no rpm reading,would this be the tach cable or would I need a connection to the R/R yellow cable for the pulse ....
Almost there but not quite....
Old Jan 16, 2018 | 10:19 AM
CaBaRet's Avatar
Those 3 wires are indeed the speed sensor, if you still had the original clocks the Yellow/Green wire from the ICM to the clocks give you the tacho pulse
Old Jan 16, 2018 | 11:42 AM
So the pink black green would connect to my new clock instead of the magnet that came with the clocks to pick up the speed...
On the wiring I found online & what came with the new clocks it states to connect yellow on my new clocks to yellow/black which I have & I'm getting no reading rpm on the clock,
Found a read up online where someone has taken a feed off one of the three yellows to the RR believe they come from the pulse generator ...
Old Jan 16, 2018 | 12:31 PM
CaBaRet's Avatar
Hi, don't know which after market clocks you have, but generally if its the magnet type that attaches to the wheel for measuring speed, then it usually comes with a tacho cable that winds around a spark plug lead for induction and after setting up for use selecting 4 cylinder works out the rpm by induction
Old Jan 16, 2018 | 01:00 PM
This is the plug that comes off the new clock which plugs into the magnet..
This is the after market clock..
It has the settings on the clocks to set wheel diameter & number of cylinders,have no other cable or coil to go around the plug.. nothing in the paper says anything about that,states which cable on the clock is tach...
Old Jan 16, 2018 | 01:33 PM
CaBaRet's Avatar
Hi , can you give me some info as to where you got it from and make, I'll see if I've got some instructions
Old Jan 18, 2018 | 03:43 AM
CaBaRet's Avatar
Found this , looks like your Koso
https://cbrforum.com/forum/cbr-600f-...n-tips-152756/
Old Jan 23, 2018 | 02:34 PM
Thanks for that I've book marked it.. just getting the resistor in the right place,hopefully fingers crossed..
Would you be able to tell me,. On the f2 the RR is bolted to a plate behind the fairings. Does it need to be bolted to the bike,does it have to make contact with the plate it's self or could this be tucked away . Thanks ...
Old Jan 23, 2018 | 03:02 PM
CaBaRet's Avatar
The plate acts as a heatsink to cool the RR, you could hide it away if you put a small computer fan on it to keep it cool
sco7tys
Mar 27, 2008 06:41 PM
StntRDR99
Sep 11, 2006 10:42 AM
golion2k
Apr 1, 2006 12:21 PM
cbr6
Mar 14, 2006 12:41 PM
