Speed Sensor 98-99 models
Old Sep 2, 2006 | 05:13 PM
StntRDR99's Avatar
Default Speed Sensor 98-99 models
I have a 99 900rr and the speedo isn't registering. Says i'm going 10mph when i'm going 50 and 15mph when i'm at 80mph.
Does anyone know if speed sensors were faulty this year or where it is on my bike? I'm pretty sure it isn't cable driven because I don't see a cable coming down to my front wheel. Is it on the Tranny/Engine somewhere?
Are these hard/expensive to fix?
I'm pretty sure the gauges are working just fine.
Any help would be appreciated!
Old Sep 10, 2006 | 01:17 AM
gixxereater's Avatar
Default RE: Speed Sensor 98-99 models
I have not heard of any issues with this, mine works fine. The sensor runs off the counter shaft, and it's electronic. I dont know exactly where the pick up is for it though. But as for a known issue, no, I have not heard anything of this sort. Probably not hard to fix if it's just the pick up. Maybe it's covered in grease or something?
Old Sep 11, 2006 | 10:42 AM
chrisf's Avatar
The speedo sensor is right in front of the upper motor mounts. Iti s a black oval-shaped plate that bolts onto the gearbox. When you remove it, it is a long cylinder with a magnet pickup at the end. This, in turn, picks up a magnet spinning on the gearbox. It actually sits in an oil bath with the rest of the gears. It's easy to remove if you think there is a problem.
With your speedo problem, I bet you have an aftermarket sprocket on the back. This is throwing the speedo way off. You might beed a Yellow Box or SpeedoHealer. I just corrected mine myself...
--Chris
LoneWolf04
Jul 2, 2010 05:37 PM
jmcshane
F4i - Wanted
May 3, 2010 01:56 PM
kukku
Nov 13, 2007 02:48 AM
neil_brit
Apr 15, 2007 10:07 AM
birdstrike
Mar 18, 2007 08:49 PM
