Overheat then no power a week later
I am currently searching through the forum. I have not found the power loss issue after a overheat. I will remove if I find what I need thanks.
96 F3 600
MY cousins somehow cracked my radiator again and the bike I beleive overheated. A week later I fix the radiator and go to turn on the bike and no power at all. I put my battery on the charger and it says fully charged. I cleaned the recepticals a little and they were tight. Checked my fuses minus the main fuse I will be doing shortly.
From what I know and have read, I should check the Regulator, main fuse. From there I am not sure. I will also take the battery in to get it tested today just in case.
96 F3 600
