NO POWER AT ALL HHHHEELLLPPP
Old Aug 19, 2007 | 02:27 PM
CBRFEAVER's Avatar
Default NO POWER AT ALL HHHHEELLLPPP
Ok i was at my local fast food joint rode into a parking spot looking all good infront of the chicks turned the bike off there all smiling and **** and when i come out there still there looking hard and got on the bike and turned the ignition on light all come on and click every thing goes off the girls start laphing lol not cool but i checked the battery got plenty of juice all the fuses are good even the main fuse off the battery checked most of the wiring not diconenects of dameged wires what couldve went wong as i push my bike down hill from a mile from my house i hop ongetting good rest then it comes to me lets turn the key on ok i did no power still but i drop it into first and pop the clutch and its running barley but running key is on and light are kinda dim i pull into my driveway and its idaling and i shut it off and turn key back on and no power still so i was running off the stator i guess whats the problem? sorry if i didnt put proper puncuations im tired from pushing and spelling i know i spelled som stuff wrong
Old Aug 19, 2007 | 03:16 PM
Scrufdog's Avatar
Default RE: NO POWER AT ALL HHHHEELLLPPP
I'll go through the basics. Check to make sure battery terminals are tight and corrosion free, check to make sure the crimps are tight as well. Check the other end of both cables as well. Grab a voltage tester and start from the battery and work your way out till you find a spot where the voltage drops. Check the starter solenoid to make sure its not all banged up.
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
