No power at all
No power at all
Having problems with my F3, Fully charged battery and working rectifier. You put the key in and turn it to the ON position and nothing happens. Nothing on the cluster, no noises, nothing. Battery is fully charged and I have already tried several.
I was having a problem with corroded battery terminals but got it taken care of. Where do the terminals lead? I'm thinking there is a short somewhere. The bike was perfectly fine before all this though.
I know for a fact it is NOT the R/R or battery.
RE: No power at all
ORIGINAL: pacemaker
Are you getting power to your lights/blinkers? Check your fuses, make sure you check the main fuse (30A) located on the left side (sitting on the bike), pull off the side cover & its to the right of the fuel pump.
Changed out the blown 30A fuse and it was good to go. Well it's on the tender right now, not sure if it's actually going to turn on yet.
So what's the deal with this thing being blown, it has never happened since i've owned the bike and i'm wondering if it's going to happen again or if I should be concerned or what?
Thanks again for all the help guys. Hope this is the last of my problems. (Unlikely)
BTW is that the starter relay fuse? I want to know what the name of it is.
