New problem
Old Jan 20, 2021 | 07:57 AM
Marzie's Avatar
Default New problem
So this morning before my daily commute in the lovely raining winter UK weather noticed a new ****le with the bike. Wheeled her out of the garage with the ignition on but the bike not started or the lights on, and noticed when i pulled the front brake that the instrument panel illuminated. I would assume i have a crack/fault within the wiring or switches which is sending power to the instruments when the brake is pressed. Anyone had a similar problem?
Old Jan 22, 2021 | 10:05 AM
Michael baxter's Avatar
Cars do this if a wrong bulb in tail lights, back feeds other bulbs through the earth circuit.
Old Jan 22, 2021 | 11:06 AM
Marzie's Avatar
That's not a bad shout, had some issues with an out rear indicator last week. Previous owner has fitted some aftermarket LED ones but not weather proofed any of the wiring. I found the problem was that the wiring had come away from the connector block used. Plans where to grimp and refit suitable connectors, will fault find the new fault first now
Old Jan 24, 2021 | 11:29 AM
Denali's Avatar
if the lights are led this can cause a sort of surge through your wiring. LED’s don’t require a lot of power so there’s excess power. One thing you can do is get an LED pulse relay? Maybe even thin wires running to them
Old Jan 26, 2021 | 01:13 PM
Marzie's Avatar
The whole wiring needs addressing to be fair, there are no resistors fitted to any of the LEDs to slow the flash rate, no weather protection and surplus wiring added for unused LED strips.
I have some options to consider, 1) convert the whole indicator system back to original, 2) tackle the current LED situation and add the resistors etc, 3) Live with the issues as I will be selling her next year.
Old Jan 26, 2021 | 05:16 PM
Denali's Avatar
hey, Marzie. Pretty sure you don’t have to do all of that resistor bullcrap. That would really suck. You can buy a led flasher relay to do that. It’s pretty much a big resistor that works for all of your lights. As for waterproofing. Heat shrink tubing is the way I went! Just giving some advice! Cheers
-Denali
Old Jan 27, 2021 | 12:54 PM
+1 for the LED flasher relay, $10 and should solve all the problems
Cheers
Al
Scottritchie
May 19, 2017 04:09 AM
opiecbr
Apr 3, 2012 01:21 PM
MidCalCbr
Jun 7, 2008 11:19 PM
vietladin
Jan 4, 2008 04:31 AM
yankcbr600
Aug 29, 2007 01:59 PM
