New problem
So this morning before my daily commute in the lovely raining winter UK weather noticed a new ****le with the bike. Wheeled her out of the garage with the ignition on but the bike not started or the lights on, and noticed when i pulled the front brake that the instrument panel illuminated. I would assume i have a crack/fault within the wiring or switches which is sending power to the instruments when the brake is pressed. Anyone had a similar problem?
That's not a bad shout, had some issues with an out rear indicator last week. Previous owner has fitted some aftermarket LED ones but not weather proofed any of the wiring. I found the problem was that the wiring had come away from the connector block used. Plans where to grimp and refit suitable connectors, will fault find the new fault first now
I have some options to consider, 1) convert the whole indicator system back to original, 2) tackle the current LED situation and add the resistors etc, 3) Live with the issues as I will be selling her next year.
The whole wiring needs addressing to be fair, there are no resistors fitted to any of the LEDs to slow the flash rate, no weather protection and surplus wiring added for unused LED strips.
-Denali
