Need help
Old May 17, 2017 | 02:01 PM
Scottritchie's Avatar
Angry Need help
I have a Honda CBR125R 2005right my problem is I have no brake lights come on at all but when I put the main fuse out for the lights my brake light works can any one help me PLEASE
Old May 18, 2017 | 04:27 AM
deaks25's Avatar
I hate electrical bugs, so hard to diagnose, please excuse the long list of questions.
Is this a problem that you've always had or something that has developed recently?
You say the brake light doesn't come on normally. Is the bulb lit up for the headlights or is the bulb just off completely.
First thing to do is check the battery is healthy. Is the bike starting ok, is the battery putting out correct voltage & holding it?
Probably worth your while downloading a workshop manual or buying a Haynes manual & checking the wiring is correct.
Old May 18, 2017 | 05:23 AM
Thank you
The bike runs like new every thing works as it should but the brake light only works when I pull the fuze out for the lights I've got the workshop book but i can't find the problem in there
Old May 18, 2017 | 08:43 AM
CaBaRet's Avatar
Hi ,will the engine start, if so does the rear brake light work when you pull the front brake lever or brake pedal ,or neither, the f2 fuse is a 10amp, and I assume yours is the carbed version
Sorry I didn't see your reply to deak25, is it f4 fuse that you pull out and it works
Old May 19, 2017 | 04:09 AM
deaks25's Avatar
No worries, you explained it better anyway CaBaRet.
Scottrichie; the reason for getting the workshop manual is to have a look at the wiring diagram & check everything is wired as it should be.
It may be something as simple as one of the bulb filaments have blown, or it may be there's an electrical gremlin in your system. As it's running normally, we can eliminate a charging problem, otherwise the engine would be struggling due to lack of battery charge.
dr.squid
Jan 28, 2018 04:42 AM
jarhead89x
Sep 26, 2008 09:38 AM
mattyggstick
Jun 20, 2008 09:22 AM
the greeen lantern
Jul 13, 2007 09:19 AM
