Missfire?
Old Apr 6, 2014 | 12:51 PM
Too slow's Avatar
New Member
Post Missfire?
Hi all, this is my first post.
Just been out on my bike again, new to me 1998 CBR600F, when I got the bike there was a full tank of fuel which had been in around 3 months according to the seller.
I have cycled 3 full tanks in the last few weekends and am still experiencing a slight issue at 3250 - 3500 rpm.
The bike feels like it is spluttering/ missing, nothing drastic and you can power straight through it. It appears most noticeable when sat at 30mph or 40mph.
I tried dropping a gear but the engine noise is too much for a newbie like me😁 I feel like a boy racer, so I have 2 choices change up and have the revs dip to 2500 or down to 4000.
The issue is only apparent at this rpm setting and doesn't affect the pull at all it's just annoying.
Please help, and Hi to you all.
Old Apr 6, 2014 | 01:47 PM
CorruptFile's Avatar
June 2013 ROTM
Clean and sync the carbs.
Old Apr 7, 2014 | 02:08 AM
Jeffcbr600f2's Avatar
Clean the carbs and see if if has a K&N filter. If it does that's likely what's causing it. This is a classic tuning issue. If you open it up it might do the same thing around 10k rpm. I'd recommend going back to the paper if if does have the K&N. If you know nothing about wrenching then you could try running a can of seafoam also. It's not a substitute for a carb cleaning but it can help if they're gummed up.
Old Apr 7, 2014 | 02:31 AM
Too slow's Avatar
New Member
Thanks for the replies, I have asked my bike mechanic if I can use his workshop with a bit of instruction. Can't beat a bit of cheap training..... Thanks again guys you have confirmed my thoughts.
Ashspike
Jul 17, 2012 04:08 PM
TechGirl1414
Dec 11, 2011 07:50 AM
Ksnapp
May 7, 2011 06:08 PM
str8krewzn
Mar 25, 2010 03:30 PM
abuser
May 25, 2009 04:24 AM
