indicator problem
Old Feb 16, 2012 | 09:00 AM
johnny ferg's Avatar
New Member
Default indicator problem
ive just bought a cbr 600f3 the front indicaters have been swapped with new leds .the indicaters on the right side are flashind at double the speed ,ive tried changing rear bulbs but to no effect is there a simple solution ..
Old Feb 16, 2012 | 06:19 PM
adidas_007's Avatar
The reason that the lights are flashing at double speed is that the Relay thinks that a light is out. Similar to how it works on a car, because the relay is not using the same wattage that it would with incandescent light bulb. You can ether change the relay to a LED relay or get load resistors to fix the fast flashing.
you can find alot of them by ether googling, or ebay.
Old Feb 16, 2012 | 07:01 PM
New Member
thanks very much ,id just found an article about flash controllers/resisters, im new to all this , very helpful
ducatijackass
F2 Tech
Mar 27, 2010 02:19 AM
ducatijackass
Mar 21, 2010 08:46 PM
Nicki RR
Aug 12, 2007 01:59 AM
Spike
Apr 2, 2007 09:51 PM
SpiritBreaker
Oct 12, 2006 10:24 PM
