how change plugs?
Old Aug 28, 2006 | 07:14 PM
TwistedCBR's Avatar
Default how change plugs?
Yanked side fairings off
Pulled tank to side
I don't see where you have room to fit anything in to get the plugs off let alone back on.
Any ideas?
Old Aug 28, 2006 | 08:16 PM
kustom98f3's Avatar
Default RE: how change plugs?
use the wrench in your tool kit or a u-joint with a plug socket on it.
Old Aug 28, 2006 | 09:03 PM
Demon RR's Avatar
exactly. go in from the side maitinence panels. and no need to remove/move the tank. just more work for you. i found using the spark plug wrence in the factory tool kit worked perfectly. just a bit tight quarters to work with.
Demon RR's Avatar
edit double post.
Old Aug 29, 2006 | 01:29 AM
weeble1's Avatar
I didn't need to move the tank at all, I just got a spark plug socket with an extention, got the extention and socket in the hole, got it tight on the plug with my fingers then attached the ratchet. Do the same to put it back in just be careful not to drop the plug in because that could mess up the gap. Get it as tight as you can with your hands because you DO NOT want to cross thread those damn plugs.
Old Aug 29, 2006 | 02:05 AM
TwistedCBR's Avatar
Now, to make sure I'm not an idiot, the plug wires are red on my bike and there are obviously four. Their is one seperate from the 3 and its on the right side (if u r sitting on the bike).
Are they easily removed and are the plugs currently in their easily removed.
ALSO, WILL THE PLUGS FROM A 94 F2 FIT IN 97 F3. I SEE NO REASON WHY THEY SHOULD NOT BUT FIGURED TO ASK.
Old Aug 29, 2006 | 07:57 PM
TwistedCBR's Avatar
Dirty mc.dirt
What a friggin mess, and thank god she's got new plugs. The existing were fine and looked as they should. Either way it runs great and I hope it will be a while till it needs to be done again. Also tightened the chain and found out that wasn't very hard at all.
Swod1
May 20, 2009 05:44 PM
600rr12
Nov 2, 2008 05:46 PM
gearhead
Jun 19, 2007 02:25 AM
shraz
Jan 10, 2007 11:15 PM
fastmofo
Dec 29, 2005 09:03 PM
