Change Plugs
Old May 12, 2009 | 07:08 PM
Swod1's Avatar
Question Change Plugs
I am trying to change the plugs on a 1992 F2, but can't get them out. If anyone has advise let me know. Thanks!!!
Old May 12, 2009 | 07:25 PM
Sand.Man's Avatar
Remove your gas tank and airbox to give you more room, use appropriate extensions for your socket wrench and be creative.
Old May 13, 2009 | 12:42 AM
Squamish CBR's Avatar
The factory tool kit comes with a special socket with a small hex on the end; use that and the wrench that fits the hex and you can get them out from the side, it's a huge pain but it can be done. Get new plugs because you won't want to do it again anytime soon!
This kind of work is usually done with other big jobs like checking the valve clearances where you take a whole bunch of stuff all the way apart, do the appropriate work and other jobs while things are easy to get at while it's apart; put the whole thing back together and try not to do it again until next time. Ya gotta plan it!
Old May 13, 2009 | 02:55 AM
rolson's Avatar
Indeed this is an annoying task. I found it best to pull the plug wires completely out of the way to free the most room, use the appropriate extension and drop that in first with the socket on it, then place the rachet on the end, and slowly turn it out. Use a spark plug socket with a rubber insert so that when your getting it out, it wedges itself in. Then, carefully pull off the rachet, and slowly pull out the extension and socket which should still contain the plug. Putting in the new ones is easier, just drop the plug in carefully, followed by the socket and extension, then on goes the rachet.
It takes time, about 45 minutes if I remember right.
Old May 20, 2009 | 05:44 PM
Swod1's Avatar
Thanks everyone for your input. The spark plug socket was the golden egg i was looking for!
Thanks again
600rr12
Nov 2, 2008 05:46 PM
gearhead
Jun 19, 2007 02:25 AM
shraz
Jan 10, 2007 11:15 PM
TwistedCBR
Aug 29, 2006 07:57 PM
fastmofo
Dec 29, 2005 09:03 PM
