Hi all and a little help if possible
AH Oh so someone has mentioned to me that before I go for the carb sync I should be checking the valve clearances, else I'll be chasing my tail. Is that sound advice?
Syncing would help with power and maybe get rid of some of that backfire. I agree that you should get the compression checked. With to much air or fuel it will run horribly. It may even stall or just plain refuse to run. Like another post I read the right fuel, compression and spark are what's needed to run the bike. Hope I helped you.
Edit: just realised your in the uk, probably dont want to ship it over the pond, what are your needle and screws set to? Do you have a jet kit? Sounds like maybe you forgot to adjust that one cylinder, too lean or too rich compared to the other cylinders could cause it to not fire at full power, if its sparking and getting some fuel i would assume an incorrect mixture in that cylinder, seems more likely than a compression leak, are you mixing any fluids?
tkidd88
Sep 13, 2013 11:36 PM
NateDieselF4i
Nov 18, 2011 09:15 PM
