HELP PLEASE!! Voltage Regulator Repair
Old May 8, 2013 | 11:13 AM
F3Kid5889's Avatar
New Member
Unhappy HELP PLEASE!! Voltage Regulator Repair
Alright guys,
1st, this is my first CBR and third bike overall, and the short one ride I have had on it has been awesome.
I bought it with a defunct regulator, so I went and grabbed another honda replacement from a scrap yard. (Not an F3 Regulator but should work from what I have read).
The previous owner had soldered the pins to the plugs and it looks like he had siliconed the connections in.
I put the pins on the new regulator yesterday, and put cables on my bike to just see if it would start.
As soon as I attached the cables, I started getting smoke from the regulator connection, and the bike kept cranking, but wouldn't turn over.
Also, the regultor got hot as s***.
I figured a regulator from a Honda would work..Am I better off to solder the wires into the tabs on the regulator and call it a day?
Why is it still smoking?
Some one please help me, I am still very Newb at this.
Tony
Old May 9, 2013 | 08:08 AM
jalen11598's Avatar
If that regulator was for an F3 it would have plugged right up but since the previous owner cut the wires your going to need a wiring chart to do it right. Also, a lot of F3 owners have upgraded the regulator from the OEM to a Suzuki regulator. You can find them for less than $50 on ebay. The regulator getting hot is normal but not the smoking of course.
If you do decide to go the ebay route, let me know and I'll take a picture of mine and try to help you out with the wiring connection.
Hope this helps. Good luck.
Old May 9, 2013 | 08:17 AM
F3Kid5889's Avatar
New Member
Jalen,
Thanks for the info! I think that I had the connections wrong like you said. Maybe thats why it was heating up prematurely, I probably had the ground and positive reversed and was feeding electricity to a pure ground, smoke being the product of that resistance.
My battery is completely dead, and I can't even charge it to test my RR now. I am going to pick up a battery after work, and plug the female to male connections through the wiring chart.
If all else fails, I may wind up going the eBay route that you suggested.
I'll let you know my progress later on tonight!
Thanks,
Tony
Old May 10, 2013 | 08:02 AM
F3Kid5889's Avatar
New Member
Jalen,
No luck man. I couldn't pull a number off of the regulator, so I am going to take it back to the Scrapyard and pick up a GSXR R/R. I am going to hardwire it in tonight and hopefully I can get it running. I will be one happy man.
I'll fill you in after the surgery.
Old May 10, 2013 | 08:39 PM
MadHattr059's Avatar
The F3 uses 3 yellow wires from the stator.
These can be connected in any order to the matching 3 on the r/r.
The red/white is positive, the green is ground.
If you got smoke off the r/r then, it's literally, toast.
The gsxr is a compatible replacement, just be sure that it is from
a bike, that is of the same or greater displacement.
Hope this helps, Ern
Old May 13, 2013 | 07:38 AM
F3Kid5889's Avatar
New Member
Guys,
I got an 05 GSXR600 rr for 25 at the scrapyard. Plugged the connections up and she still wasnt firing. I had figured out that since I kept trying to turn her over, i probably fouled the plugs. Sure enough I replaced the NGKs and the turned over on the first crank.
I had it out for 45 minutes the other day and no problems at all. I have to stop and buy a new multimeter, I lost my old one in the move I think. It seems as though the rr is doing its job, no weird idle, battery is holding a decent charge.
Thank you guys for all the help!
Jp Provence
Apr 24, 2012 10:36 AM
ldgriffin
Sep 22, 2010 03:52 AM
vaggabon
Jun 1, 2007 01:37 PM
crashhypermonkey
Aug 13, 2006 10:16 PM
