HELP HELP HELP!!! 98 wont start, just get a click and nothing!!!!
I have a 98 f3 with 10,000 miles on it, never no electircal problems before.....i went to get on it and start it and I turned the key to the on position and everythings was normal, but when I went to Hit the start button, i pushed it and it went click! and the oil/neutral/side stand lights went out and nothing after that!!!!i checked the battery and it has 12.89 volts and i did a check on the relay under the seat and its Okay! could it be the ground wire or the starter? selonoid!??????????? has anyone had this same problem before!!?????
RE: HELP HELP HELP!!! 98 wont start, just get a click and nothing!!!!
keep a meter on the battery while you try to start it. if it drops below 10.0 volts its more than likely bad. if it doesn't change i would check the battery connections at the battery and at the starter. Batteries can show good voltage without a load and completly crap out once there is a load applied
