Which GSXR Regulator?
Old May 6, 2010 | 12:56 PM
dman81's Avatar
Default Which GSXR Regulator?
My regulator is dead. I have read that you should replace it with a GSXR, but what sizes are okay to use with my bike (600 F3)? The one from a 600, 750, 1000?
Anybody able to help me?
Thanks
Old May 6, 2010 | 03:08 PM
willduce's Avatar
dont think it matters, almost all "modern" sportbikes use the same style of r/r. its just a matter of hooking the right wires up to the right wires.
Old May 8, 2010 | 08:46 PM
kjohnson's Avatar
'03-'05 GSXR r/r
Top 3 wires go to the stator
the other 2 are pos/neg
Old May 8, 2010 | 09:28 PM
Red_Eye's Avatar
It's funny, on another forum the guys with gixxers were switching to Honda R/Rs. I asked why they'd do that, when the Honda guys are always replacing them with Suzuki units . . . I was told that the Honda rectifiers are fine, it's the wiring that's crap and leads to them failing. So maybe upgrading the wiring harness and connectors would help . . .
Old May 13, 2010 | 11:18 AM
Dlee's Avatar
so i my regulator burned and melted..... i bought the gsxr unit and have one question.
- for the stator wires, do they have to be in a certain order? (would it charge the battery backwards if one of the legs of the stator was out of order?)
thanks in advance
Old May 13, 2010 | 12:04 PM
Dlee's Avatar
nevermind.. i found my answer and a lot more here.. thanks all
http://www.triumphrat.net/speed-trip...r-upgrade.html
Old May 19, 2010 | 12:35 PM
Dlee's Avatar
just installed the gsxr R/R popped a couple main fuses, but that was due to installing the r/r incorrectly..
after searching and searching.... i never found which wire goes where, so incase someone w/out a multimeter has to make the change:
3 wires from the stator - doesnt matter where each goes.
wire with red stripe(gsxr side) - connect to red wire on the f3
wire with white stripe(gsxr side) - connect to green wire on the f3
VERY EASY TO DO.
Old May 19, 2010 | 03:19 PM
dman81's Avatar
Thanks Dlee, I ordered one as well and it should be in tomorrow. So this will help me.
Old May 19, 2010 | 08:52 PM
willduce's Avatar
be careful on that triumphrat site, those guys can be ******** haha
interesting tidbit.......i ordered a gsxr r/r for my triumph cause they are so abundant and it was the exact same one as the stock triumph (plug in and all) which made for a simple plug and play replacement
suzuki2903
Apr 3, 2009 05:06 PM
noobF3er
Aug 15, 2008 11:55 PM
Cryo
Jul 15, 2008 11:40 PM
cdpadilla600rr
May 3, 2008 02:38 PM
