F2 speedo and tach on F3?
Old 01-26-2008, 12:30 AM
95Cbr6's Avatar
Default F2 speedo and tach on F3?
I have a 95 f3 and it has an f2 motor swap. Since it has the f2 motor there is no way to connect the speedo, can i use an f2 speedo and tach on the f3 chassis? does it bolt right on, any modifications needed? help
Old 01-26-2008, 06:42 AM
kjohnson's Avatar
Default RE: F2 speedo and tach on F3?
F2 speedo is driven from the front wheel,the F3 comes from the engine.You'd need an F2 front end to get your speedo to work.
Old 01-26-2008, 08:25 AM
95Cbr6's Avatar
i wouldn't be able to just use the front wheel?
Old 01-26-2008, 11:54 AM
kwong2001's Avatar
You might want to try posting the same topic in the F2 section, they'd probably have a better idea of what's involved.
Old 01-26-2008, 04:41 PM
kjohnson's Avatar
Fork leg lowers,wheels,calipers and fenders must match.None of these will swap.
F2 speedo is driven from the front wheel and is spaced accordingly.Plus the brake rotors are a different size,hence needing the matching brake calipers.The calipers mount to the lower legs in different places on the legs,and the calipers are different.
Old 01-26-2008, 09:10 PM
Dude! why do you have a F2 motor swap? you do know the F2 is a detuned motor? lower HP and torq carbs are smaller its a hole crappier motor, not saying that you bike is slow or somthing but if i did a swap, it would be with a 900rr motor or just have you motor rebuilt better so if i offended you in advance
schemefighter
04-13-2013 01:51 PM
morfoot
09-10-2007 09:32 AM
DVSGVS
05-04-2007 09:14 PM
matt_m427
01-28-2007 04:02 AM
Quick Reply: F2 speedo and tach on F3?
