F2 speedo and tach on F3?
I have a 95 f3 and it has an f2 motor swap. Since it has the f2 motor there is no way to connect the speedo, can i use an f2 speedo and tach on the f3 chassis? does it bolt right on, any modifications needed? help
RE: F2 speedo and tach on F3?
F2 speedo is driven from the front wheel,the F3 comes from the engine.You'd need an F2 front end to get your speedo to work.
i wouldn't be able to just use the front wheel?
You might want to try posting the same topic in the F2 section, they'd probably have a better idea of what's involved.
Fork leg lowers,wheels,calipers and fenders must match.None of these will swap.
F2 speedo is driven from the front wheel and is spaced accordingly.Plus the brake rotors are a different size,hence needing the matching brake calipers.The calipers mount to the lower legs in different places on the legs,and the calipers are different. |
Dude! why do you have a F2 motor swap? you do know the F2 is a detuned motor? lower HP and torq carbs are smaller its a hole crappier motor, not saying that you bike is slow or somthing but if i did a swap, it would be with a 900rr motor or just have you motor rebuilt better so if i offended you in advance
