Engine Seize up
Old Aug 11, 2007 | 01:39 PM
Jayced1's Avatar
Default Engine Seize up
Hello,
I was woundering can my engine seize up from a oil leak if the bike is just sitting? I have a broken shift shaft oil seal and my oil is leaking at a fast rate. Would the engine seize up once the engine is cranked or will the engine automatically seize up without being cranked? Or will the engine be fine? Whats the best way to combat this issue? Thanx
Old Aug 11, 2007 | 02:03 PM
HAVOC's Avatar
Default RE: Engine Seize up
with the bike just sitting and not running your motor will not lose all the oil it needs to keep the internals lubricated. so dont worry about it seizing up just dont run the motor without oil and you'll be fine
Old Aug 12, 2007 | 05:13 PM
redzintimidator's Avatar
Are you going to get that fixed soon??
If you have some time before you get it fixed, make sure to keep it full and dont take the chance by starting it.
Old Aug 13, 2007 | 09:09 AM
MikeInCtown's Avatar
if the oil leaks out it could start rusting internally which would be a bad thing. If the leak isn't too bad, I would at least put some oil in there every once in a while and get it started.
Old Aug 13, 2007 | 10:21 AM
madmike01uk's Avatar
Just fix the leak = problem solved
Old Aug 13, 2007 | 10:39 AM
marc0011's Avatar
I would fix the deal too. It takes about fve minutes and $2.00. It is a very simple fix andrequires minimal tools.
Old Aug 13, 2007 | 11:28 PM
Push's Avatar
Pay a little now or a lot more later...
Old Aug 14, 2007 | 01:15 AM
marc0011's Avatar
I think Push has the best advice thus far on this.
jayofnazareth
May 26, 2011 12:08 PM
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
