engine not cooling
#22
If it were my bike, that's what I'd do. One thing I'd do to double check is put your hand on the hose that exits the radiator. If it is noticeably cooler than the rest, it's a good bet that the thermostat is stuck.
If you do swap it out, be prepared to catch all the coolant as well as have new on hand to replace what you will need to drain out.
Hope this helps.
Hope this helps.
#23
You have no cross contamination, & no more leaks.....correct? Have you set it on the side stand & let it run for a few to burp out any air bubbles? What are the temps getting up to? You can use a cooking thermometer to check the temp at which the fan comes on. It should come on around 210ish if I remember correctly when the system is sealed up.
#24
