929 Cooling fan
Old Jun 20, 2008 | 10:08 AM
FlynHigh71's Avatar
Default 929 Cooling fan
My cooling fan is not kicking on and the bike is reaching extreme temps. I have checked the fuses and they are all fine. Any ideas where I should start on fixing this. I have no problem replacing parts but how can I tell what is actually broken.
Old Jun 21, 2008 | 04:54 PM
HondaTech68's Avatar
Default RE: 929 Cooling fan
ok at the bottom of your radiator there is fan switch it looks like a big plug with one wire coming out of it unplug the wire and touch the connector of that wire to groung if it wont reach get a wire and jump it when you do this the fan should come on if it does its most likely your fan thermal switch is bad now if it doesn't check to make sure you have power coming out of that wire if you do then its most likely your fan motor
Old Jun 22, 2008 | 03:17 PM
FlynHigh71's Avatar
Ok thanks for the help, gonna get to work here in another day and get this all worked out.
stealthCBR929
Nov 8, 2011 11:49 PM
scooterc14
Nov 4, 2011 01:06 PM
(951) Baby Shortee
Dec 8, 2009 01:52 PM
Bran Bel
Sep 13, 2007 07:03 PM
JIMMYC
Apr 19, 2007 12:47 AM
