electrical problems
Old Nov 7, 2007 | 03:18 PM
rblevins4130's Avatar
Default electrical problems
ok i have a prob...still 97 cbr and i was riding at like 60 miles an hour and...all the gayges sweeped to 0.. and nothing but the headlights work and ignition...i have justrreplaced r/r 30 amp fuse and fule cut off relay...and batt so ...it starts and runs off gravity feed ...but thats it i have no power to anything else........i dont noi what to do can someone please help
Old Nov 7, 2007 | 05:10 PM
Default RE: electrical problems
im shocked all these mot burus on here and no one nos anything....
Old Nov 8, 2007 | 05:55 AM
marc0011's Avatar
You have another set of sub fuses just under the right faring, did you check those? If all your fuses are in good order, then you're going to have to poke and prod around. Do you have a volt meter? If not, I recomend investing into one becauseit is the only the only tool that will help you figure this out. You can geta digital oneat Radio Shack for like $20 which will perform many functions.
I was looking over a wire diagram and if you have no blown sub fuses, check to see if there is any power there with the fuses out (one side should light up). You should have power there since your headlight is working. I would also look into your engine stop switch. There is a Black/White wire and it should have power there. It's also part of the same Black/White wire that leads to the Fuel Relay, check to see if there is voltage there. By the way, do you have a wire diagram? Check these couple things out and get back with what you find.
Old Nov 10, 2007 | 01:36 AM
yeah i have power to it...and i have a diangram...........switch works and fuses are fine
Old Nov 10, 2007 | 04:36 PM
marc0011's Avatar
Sounds like it is two things, your gauge cluster or you Ignition Control Module (ICM). I'm suspecting the gaugel cluster more than the ICM because the engine runs when by passing the fuel pump and it's easier to check. Check the connections in the back of your gauge cluster for power. I would also check the continuity of your ground (Green Wire & Green/Black Wire). You could have a bad ground that is causing all this. There is a ground connection that is located right next to the Regulator/Rectifier (R/R), make sure it's good.When doing the continuity test, contact one probe with the Green Wire & Green/Black Wire while touching the other probeto theground connection on the frame that is right behind the R/R. You should get a chime out of this, if not, you have a bad ground. Do you have a multimeter?
dcaldwell
Oct 6, 2009 10:20 PM
thetrick13
Aug 11, 2009 10:13 AM
the_gambler
May 15, 2009 11:15 AM
f3gatorfan3388
Nov 19, 2007 02:28 PM
dizzie56
Jul 9, 2006 01:59 AM
