dang rectifer
Old Apr 22, 2007 | 12:51 AM
lldreams's Avatar
Default dang rectifer
ok so my regulator has went out for the second time!!!![:@] are the regulators with the cooling fins better then without? also where do you guys think i could get this the cheapest? i found one with fins for 74.99 http://www.regulatorrectifier.com/ca...2ebaeb343f8007
Old Apr 22, 2007 | 12:18 PM
Ar15 guy's Avatar
Default RE: dang rectifer
Use a 2004 GSXR1000 rectifier. Thats what I did on my f2. Worked awesome,
Search for a thread titled R/R problem solved or something like that. It gives you the rundown on the setup.
Old Apr 23, 2007 | 12:31 AM
lldreams's Avatar
ok question would it harm anything if i just kicked started my bike all the time and left the battery out and disconnected? also would my lights and stuff power of the alternator
Old Apr 23, 2007 | 01:42 AM
HAVOC's Avatar
our bikes need the battery to be able to run our electrical system. it isnt like a car where you can dissconect the battery and let it run on the alternator alone.
you said that your regulator has gone out 2 times on you. when it happened the 1st time what did you do ? how did you fix the problem ?
Old Apr 23, 2007 | 12:31 PM
lldreams's Avatar
ok well it is for sure the rectifier. today i jump started my bike and checked the voltage at the battery with the bike running and at about 4k rpms. the battery voltage was at like 22-23 volts. [:@] just replaced the stupid thing march 27th.[:@]
Old Apr 23, 2007 | 06:00 PM
LlanoSV's Avatar
ORIGINAL: lldreams
Shouldn't the volts at the battery when running at that RPM be around 15volts? I just replaced mine with the 05 GSXR 1000 and it only goes to 15 volts at 5000 RPMS
flhticbr
Dec 19, 2011 06:07 PM
sstgonzo
Jul 18, 2007 09:24 PM
phastjwd
Nov 27, 2005 08:48 PM
Slowrider
Nov 3, 2005 01:41 PM
