changing my gauges light bulbs
Old Feb 5, 2011 | 03:54 PM
Morganjh17's Avatar
Default changing my gauges light bulbs
Can you change the color of light bulb in the back of your gauges? or is is a plastic cover to make them glow orange? i want them to glow blue, so what should i do to make that happen?
Old Feb 6, 2011 | 02:03 AM
revilingfool's Avatar
okay so im not familiar with the f3 cluster but i did read a how to on color change once for another model (digital speedo w/ regular tach.), i assume they would be very similar.
On that model the light comes from a couple LED's that are soldered onto the circuit/chip thing behind the gauge face. It involves taking out the gauges, separating the chip from them, then unsoldering the LED's and resoldering them with the color of your choice, or maybe multiple colors could be cool. like blue up to 6k, then orange at power and red up top.
there could be a better solution to this... like i said my info is not bike specific
Old Feb 7, 2011 | 10:13 AM
Morganjh17's Avatar
Well i was looking at the back of my gauges and all i saw were little light bulbs i can pop right out but im not sure if they're giving the light or if theres a red film they just make it look like they glow orange. But i dont want to rip apart the cluster to find out so i dont mess anything up =) but i couldnt find anything online about color change that wasnt really expensive =\
Old Feb 7, 2011 | 11:40 AM
Veibz's Avatar
superbrightleds.com is a good source for LEDs. If you can find out which size LED's are in the cluster you can find them pretty easy on that site.
My Dodge Ram had screw in LED bulbs for all the gauges...when they burnt out I replaced them all with blue LEDs from that site. Now, I just take the part # and cross it over in Ebay and you can generally safe a few more $.
I was thinking of changing the lights in my cluster of my f4i so I was kinda poking around as well.
Old Feb 13, 2011 | 01:55 AM
To_Endanger's Avatar
Check this thread;
https://cbrforum.com/forum/how-mechanical-40/how-f3-hid-install-112864/
Haven't done the hid yet, but i did order the bulbs and they are a lot brighter. Except the white ones that are meant to be spread to light up the guages. My temp gauge is barely lit. But still visible. So I think you would have to replace the green 'film' or whatever is back there behind the actual gauge to change the color.
Sandor
May 5, 2011 07:39 PM
hoeft
F2 Tech
May 6, 2010 04:13 PM
Vidra
Oct 5, 2008 08:08 PM
slowpoke
Sep 3, 2006 03:12 PM
hibby11
Apr 27, 2006 03:33 AM
