changing brake pads
Old May 11, 2007 | 11:55 PM
bluestanger66's Avatar
Default changing brake pads
are changing the break pads on my f3 hard? or is it just the one bolt holding them in? i have the tire off and i thought this would be prime time to change pads? will i need to re-adjust them when i am done replacing them? thanks!
Old May 12, 2007 | 12:32 AM
mccannf3's Avatar
Default RE: changing brake pads
Its not hard at all but you must be patient and use the right tools. The easiest places to really screw **** up is removing the cover to the bolt to remove the pads. Be patient with the flat tip screw driver when removing the cover, it would be very easy to strip the head off. After you remove the cover be sure to use a 5mm alan wrench to keep from stripping the bolt.
Old May 12, 2007 | 01:58 PM
ryanfeldman's Avatar
if you have the manual, look there. i had to replace the brakes for my bike to pass inspection and it took me maybe an hr or so for both the front and back.
Old May 12, 2007 | 04:17 PM
pointman's Avatar
you may as well bleed the brake fluid to makes it much easier
jeffjones
Oct 27, 2010 12:38 PM
CYCDUP
Aug 20, 2009 06:13 AM
G3NESYS
Apr 11, 2008 12:29 PM
sstgonzo
Aug 17, 2007 01:09 AM
fading@verizon.net
Oct 17, 2006 07:39 PM
